Clutch pedal keeps getting softer and softer, but no slippage
Old Feb 10, 2008 | 10:29 PM
96supersport's Avatar
What would that be, pressure plate going bad? Master? Slave?
help please.
Old Feb 11, 2008 | 01:47 AM
GreasyB's Avatar
Try bleeding your slave/master cylinder for your clutch. If that doesnt help at all my guess would probly be your pressure plate is getting worn and losing tension.
Old Feb 11, 2008 | 08:22 AM
yea but if the pressure plate was getting weak wouldnt it slip pretty noticeably?
i think im going to pull the hydrualics and take a look at them.
Old Feb 12, 2008 | 11:35 AM
help anyone?
it doesnt slip like it would be if the pressure plate was weak, but its not losing fluid.
and the pedal is getting softer the more i drive it.
Old Feb 12, 2008 | 10:06 PM
Green96Z's Avatar
You might be sucking air into your hydraulics. Check the reservoir cap first. Then bleed it. After that you might have to remove the hydraulics and closely inspect the lines and connections for any leaks.
Old Feb 12, 2008 | 10:31 PM
im going to replace the slave friday, because it seems to be leaking just a little bit into the bell housing.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
