clutch problems
Old Mar 11, 2008 | 07:56 PM
Borlaz28's Avatar
clutch problems
Hello everyone!
I have a 95 z28 m6 things have been great in this car untill one day I lost most of my clutch pedal. I goes most of the way down until anything happens and the pedal seems to shake. I made it home looked under the hood and no fluid in the clutch master cylinder. I looked for a leek but everything is dry. ( not sure how ) but my question would be what the best way to bleed the clutch? Sorry I've always owned the auto's. Any info wsould be great and thank you in advance.... james
Old Mar 11, 2008 | 08:38 PM
greenmachinedriver's Avatar
the fluid had to go somewhere. look undre the dash at the clutch pedal whre the pushrod goes through the firewall. also try pulling out the slave cylinder to see if it is leaking, it can be hard to tell with it in the tranny still. bleeding a clutch is alot like bleeding brakes. pumpp the pedal and hold down while someone opens the bleeder screw, close the bleeder screw and release the pedal.
Old Mar 11, 2008 | 08:57 PM
Borlaz28's Avatar
hey thanks alot. I feel the same way it didn't just vanish it went some where but where i'm not sure. I think this weekend I will start to tare things apart. I just hope the clutch is ok. thanks again..
Old Mar 12, 2008 | 12:53 AM
acre's Avatar
Another option to bleed the clutch can be found here
Old Mar 12, 2008 | 08:01 PM
Borlaz28's Avatar
vac
That looks easier then how the service manual shows. I got under the car today and relized the front seal had been leaking for a while so it will be hard to tell if anything else was leaking. time to show her some attention i guess. thanks i think i might try the vac...
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
