Had my flywheel resurfaced while out ,but still have questions
Old Feb 13, 2008 | 10:16 PM
Dave1980's Avatar
I got my flywheel resurfaced while being 0 balanced today. I want to know if there is a clutch break in, even though I will still be using my old disk till its done.
In other words, does the flywheel need to have the clutch surface impregnated on it before you can really get on the gas?
Old Feb 14, 2008 | 01:24 AM
95LT1conv's Avatar
Why did you have it zero balanced? If you are still running a stock engine, you can most likely expect some pretty serious vibration as the flywheel is what balances the engine. LT1s are externally balanced if you didn't know.
Old Feb 14, 2008 | 01:46 AM
Green96Z's Avatar
Get it balanced back to stock. The stock engine has in internal front balance and external rear, meaning the flywheel balances it.
And why would you use the old clutch disc to break in the flywheel, only to switch it out later? That's stupid. Just stick the new clutch in there and be done with it. Break in time is 500 miles.
Old Feb 14, 2008 | 05:39 AM
rskrause's Avatar
Moderator
Yes, take it weasy on it at first.
Rich
ps: give the guy some credit and assume he needs it zero balanced.
Old Feb 14, 2008 | 07:22 AM
Dave1980's Avatar
well cause I am running an internally balanced motor. Why question what I have done? Read my sig, it should give a hint.
Are you kidding me? Its not the stock clutch disk, it is spec stage 2 and i cant just throw that out if it was working fine.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Ringmaster72
Feb 25, 2015 03:15 PM
Newgmman
Feb 25, 2015 02:53 PM
HectorM52
Jan 30, 2015 11:08 PM
mattszm6
Dec 14, 2014 07:09 AM
