HELP! Axles have in-out motion, what is causing it?
Old Feb 12, 2008 | 04:09 AM
flexus's Avatar
I've taken the wheels off and the axles are moving in and out. I looked inside the diff and the 2 plates holding the axles apart fell out when i unscrewed them. The left axle has pretty big movement (about 2mm), the right one (it's almost new, has but a few thousand miles on it) just a little. The plates holding them apart don't seem to be worn or anything, the C-clips do look worn though.
What do you think could cause this movement? Is it possible for the left axle to have worn out at the head so much or is it just the C clips? The car is manual, with torsen, 57000 miles (not sure if it has been tempered with).
Please help!
Thanks, Felix.
Old Feb 12, 2008 | 08:14 AM
jay_lt4's Avatar
it is normal for c-clip axles to have some movement in and out,,, i would not worry about 2mm of play in the axle
Old Feb 12, 2008 | 08:16 AM
flexus's Avatar
I'm worried because it had no play 6 months ago and when i drive it makes clunking sounds that it wasn't doing before... When i cruise (not in gear) i can hear it like a cyclic metallic beating...
Old Feb 12, 2008 | 04:00 PM
flexus's Avatar
ttt i need more oppinions please i'm not sure what i'm supposed to do!
Old Feb 12, 2008 | 06:40 PM
matLT1's Avatar
You're fine. In-out motion of the axle shaft is typical.
Old Feb 12, 2008 | 07:14 PM
dangalla's Avatar
yeah i would have to agree that some in-and-out is ok, but i think you should continue to investigate the clunking and metalic sound, maybe bearings?
2QUIK6
Sep 17, 2016 02:31 PM
techstar
Aug 6, 2015 11:20 AM
Aug 5, 2015 08:35 AM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
