Bad Engine or Tranny Mounts??
Old Jul 15, 2004 | 01:53 PM
rokudan's Avatar
I have a 2001 Z28 and have noticed a bit of a thud at times when the tranny downshifts (automatic)
Mind you I drove a 4 cyl for the past 4 years, so maybe it is just something I am not used to. But it happens typically at lower speeds. If I give it a little gas and it drops down a gear, I get a noticable thunk as if there is a bad mont somewhere. Is this just the way these cars are, or is something really broke and needs attention?
Old Jul 15, 2004 | 02:26 PM
FastrDamnit!'s Avatar
Lightbulb
It's probably just the trans-mount (pretty cheap/easy fix).
Does it feel like it's coming from the floorboard/console area?
You can pick up an Energy Susp. poly-mount at most autoparts stores for about $25. Just make sure to modify the mount by shaving the pre-load bumps and do not use the extra metal plates that come with it.
This prevents excess vibration and keeps the trans positioned at the same height as your factory mount.
Hope this helps.
Old Jul 15, 2004 | 02:56 PM
rokudan's Avatar
Exactly right.. The thud seems to come from under the floor board. I was figuring it may be the trans mount. I have not yet had a chance to get her up in the air to take a look, but will this weekend.
Since "A Little" is relative, I am not sure if I would say it is a little or a lot. To me it is quite noticable. But I am usually very acute to such things. Like said, I will get her raised this weekend and see for sure.. Thanks for the info guys!!
Old Jul 15, 2004 | 08:51 PM
1stls1's Avatar
Even easer way to check, just power brake it. If you feel a knock under the floor, is your trany mount.
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
