Crush collar or solid spacer
Old Jul 11, 2004 | 12:30 AM
ArizonaZ's Avatar
What is the purpose of the crush collar in the rear end, just to help with preload? also, is a solid spacer better in any way than a crush collar?
Old Jul 11, 2004 | 10:29 AM
Grease's Avatar
the crush collar is there to get the right pinion depth. And a solid pinion spacer is way better than a crush collar.
Old Jul 11, 2004 | 12:44 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Both the crush collar, and solid pinion spacer is there to keep the pinion tight. (It wouldn't normally take a few hundred ft lbs to get the correct preload on the bearings).
I don't use either. I set bearing preload, then tack weld the pinion nut to the gear.
Old Jul 12, 2004 | 05:30 AM
SABLT194's Avatar
Ding, Ding, Ding! The right answer is INTMD8! I haven't done the tack weld deal yet but it certainly should work just fine (just makes disassembly a little more of a pain.)
Steve
Boss002
Jan 20, 2016 12:17 PM
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
