Slave Cylinder
Old Jul 6, 2004 | 12:59 PM
Jasonz28camaro's Avatar
Slave Cylinder
Where is the cheapest place to buy a replacement Clutch Slave Cylinder or even a slight upgrade to the stock one?
Old Jul 6, 2004 | 02:39 PM
rlax31's Avatar
You can go to the dealer, or one of the guys here who can get GM parts for cheap, but it will come with the whole hydrolic system pre-bled. I think it's around 125 from the dealer. I know they make aftermarket master cylinders, I have one in my car, but I don't ever remember seeing aftermarket slaves.
I have an extra slave actually, It's got about 20k on it, but there is no problems with it that I know of. I baught the whole system new when I was doing my 6-speed swap because the master had a tear in it, so I have an extra slave sitting around. I'll sell it to ya for 30 bucks.
Old Jul 6, 2004 | 04:00 PM
JordanKeller's Avatar
It was $169 I believe... I just bought one about a week ago... the clutch/slave.
It comes pre-bleed, just toss it in and go.
They are a bit of a bear to install though.
Old Jul 6, 2004 | 05:07 PM
R8E1D's Avatar
Advance auto sells the slave by itself, but then you have to bleed it with the master. The slave is easy to install but the master is a pita.
Old Jul 6, 2004 | 05:41 PM
Super Slow '97's Avatar
Call Dal he will get it for you cheap. I believe that I got mine for around $100. He is a parts man at a dealer. If you want more info on him try a search there is a lot out there.
Dal 877-448-5451
Old Jul 7, 2004 | 05:20 PM
thanks guys =)
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
