rear end
Old Jul 6, 2004 | 04:51 PM
durtybird's Avatar
rear end
can i put a 4th generation rear end into a 3rd generation easily
Old Jul 6, 2004 | 05:13 PM
It will bolt right in, no problems.... except the 4th Gen rear axle assembly (if you are talking about the complete assembly) is 3" wider than a 3rd Gen rear axle. You would need to switch to 4th Gen offset wheels.
Old Jul 6, 2004 | 05:17 PM
durtybird's Avatar
i dont get what you mean by offset does it mean i just need 4th generation rims
Old Jul 6, 2004 | 06:32 PM
Jay-Roll's Avatar
Yup that's what it means. If you stick with your current 3rd generation wheels they will stick out 3 inches on both sides. Basically they probably won't fit anymore and will rub all the time. Switch to either 4th gen wheels, or aftermarket wheels that have the same offset 4th gen wheels have. Then you'll be just fine.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
