What is the minimum speed you should cruise in 6th gear?
Just as the title says, having a bit of a debate in another thread about it so I decided to move it here. I think 45 MPH is just fine as long as your not accelerating. Your just cruising while getting better gas milage than if you were in 5th gear at the same speed. Doesn't bog or anything...
http://web.camaross.com/forums/showt...hreadid=272980 Thats the other thread....
I do not know if there is a minimum recommended speed when you should be in 6th.
Personally I wait till I'm going at least 65MPH, I hit 5th at about 50-55 and most of my city driving is in 3rd or lower.
I would think that the car would be a dog in 6th at 45mph, fine you may save a few bucks on fuel but I find that running the gears is 1/2 the fun of owning this car.
Then again I'm one of those guys whose first mod was !cags and a new shifter
Re: What is the minimum speed you should cruise in 6th gear?
Any stock LS1 (or LT1) is made to pull wide open throttle from very low rpm. They do it on the dyno all the time. If you are in 6th at 1000 or even less and you need to accelerate, push on the pedal. If the engine doesn't like it, it will tell you. If you are approaching full throttle, AND the car isn't accelerating fast enough for you, down shift a gear or two or three. In normal suburban traffic we encounter, rarely is a downshift necesary to keep up with traffic.
If you start off easily in first and get the 1-4 skip shift, look at the rpm in 4th.
For least engine wear and best fuel economy, run in the highest gear (6th being highest) the engine runs smoothly. If you experiment with this you'll find it's a lot lower speed than you expected.
I don't expect many folks to agree with me on this, but you asked.
My highly opinionated $.02
I don't go so much by MPH but RPM. I try to stay at 1200+ on the highway which equates to ~60-65MPH as my lowest MPH in 6th.
Through the city I try to stay around 1800-2000 for hills, traffic, etc. I figure the money I'd save in gas by running 1200-1500 through the city would go out the window for a new clutch because I'd have to do so much more shifting.
Guest
Posts: n/a
I'm like Meccadeth, I used to cruise around town in 6th all the time. Naturally, there's not a lot of get up and go, but it will pull itself along and usually handle even some small hills. Of course, I had the king of low end torque, teh El Tee Won
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 30, 2014 08:41 AM
