How much fluid is needed for tq conv. and shift kit install?
Old Jun 24, 2004 | 02:14 PM
Jay-Roll's Avatar
The converter is already full of fluid, and we're having a guy install a trans-go along with a new filter. So how much fluid is it gonna take to do this swap? I bought a gallon thinking that would be enough to fill er back up, but then realized if the pan is coming off I'm probably gonna need a lot more. So how much should I get? I'm using Dexron - III btw. Also should I wait until the tranny is back in until I fill it back up, or do it after the pan is back on? I know it's gotta be lighter without fluid, every little bit helps.
Old Jun 24, 2004 | 03:14 PM
dreamer1q's Avatar
In my old A3 setup with 2 coolers and a normal depth pan I would need 13 quarts. The more fluid you have, the cooler it stays.
Old Jun 24, 2004 | 03:24 PM
Jay-Roll's Avatar
oh I forgot that....there's a B&M 24,000 GVU cooler in the mix too. I guess I better go buy a couple more gallons. It's best to check the fluid level with the car running right? Does it really matter if it's warmed up.
Old Jun 24, 2004 | 06:06 PM
Jay-Roll's Avatar
No I'm just using the stock pan for now since I don't have a filter that will drop down into an aftermarket one and I already bought the replacement. I think I'll be good with atleast 3 gallons maybe 4. Figuring 4 quarts to a gallon and theres 12 quarts in a case = my 3 gallons(for you lazy math types).
What about checking the fluid level? With car running, up to temp or just running?
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
DarkHorse
Aug 1, 2002 04:59 PM
mjcent922
Jul 27, 2002 12:42 PM
Jake77444
Jul 21, 2002 05:37 PM
