bellhousing stuck? what do to?
Old Jul 4, 2004 | 06:42 PM
airborneluva's Avatar
is this right? the trans is bolted to the bellhousing- and the bellhousing is connected to the block? right now i have removed 7 bolts from the bellhousing to the block but nothing is moving. Should i remove the trans from the bellhousing first or am I missing a bolt somewhere? help ! hehe
thanks
Josh
Old Jul 4, 2004 | 06:47 PM
IllusionalTA's Avatar
I'd say put 2 bolt's back in the bell housing.. remove the tranny from the bell housing and then pull the bell housing off.. have you pulled the clutch fork off the T/O bearing yet? that could be holding it on as well.. Its easier the way i mentioned trust me..
68camaroboltz
Oct 5, 2015 11:56 PM
buggy323
Jul 1, 2015 04:37 PM
sherwinZ28
Jun 6, 2015 08:48 PM
tds1213
Nov 27, 2014 12:55 PM
