Ford 9" rearend switch???
Guys may be a dumb ? but keep in mind that I am an idiot as far as working on cars. Have heard stories about the rear end breaking in our camaros and everyone talks about if it does they will get a Ford 9" rear end. ? is it as simple as finding a wrecked mustang and buying the rear end and making the switch?
Re: Ford 9" rearend switch???
its true that the stock f-body 10-bolt rears are a little fragile but they probably won't break if you don't launch em on sticky tires too much. there ARE guys going 10s on stock 10-bolts...they won't last forever but they aren't toothpicks either (though i did break one already.)
your best bet is to buy a converted f-body specific rear axle from a reputable company (moser etc.) you could always go with a GM 12-bolt as it really only tolerates about 4% less hp/tq then the ford 9 inch. 12 bolts are usually sufficient for most upgraded f-bodies. if u really want the 9 inch, they make f-body specific rear axles for those too. shop around.
How much hp are you making? Do you go to the track much? Are you still running a stock gear? I would not worry about your rearend until you start making some good hp and start running sticky tires.
im still running a 10-bolt in my car, and it 60 foots pretty hard so u may not need to worry about a rear right now.
what exactly is ur setup? tranny? modifications? tires?
I am running a stock gear now after my 4:10 was shredded all to pieces. MT slicks, 175 shot of nitrous, 4:10. and bunch of bolt ons does not make for a good combination. Have to admit though it held up for almost a year before rear end gear expolded
If you are planning to spray the car and run a sticky tire than it is time to upgrade to a better rearend. I am assuming by stock you are running a 3.42 gear? The funny thing is that I have seen stock rearends take tons of abuse. Typically, people start encountering problems when they change out the rearend gears and go with a 3.73 or 4.10. But I still would not upgrade until you break the rearend. The reason the 6 speed is more violent than the auto is because you are basically shocking the driveline rather than preloading it with an auto.
