What driveshaft do I have?
What kind of driveshaft does my car have? When did they start putting aluminum in the cars? I have a 97 Z28, I have bad vibration after 90, just wondering if an upgrade to an aluminum shaft would help.
Most likely you have a steel drive shaft. Take a look under the car, if its rusty looking than its steel, if its still silver than its probably aluminum. Any f body from 82-02 will fit your car.
Originally posted by Jay-Roll
I believe Aluminum DS's weren't on F-bodies until the LS1 era. So one year after you. An AL DS should eliminate the high speed vibration. Or you could just get yours balanced.
That's what I'd get [and have ] as a replacement ..
about 230 from Cromer
I will warn you that LS1 driveshafts are not a fix-all for the vibrations...
I put one in my car thinking it would solve the vibration issue I was having (Anything over 70-75 was completely untolerable).. it made me be able to to 75-80 instead....
I coughed up the $$ and bought a Denny's Nitrous Ready and now... it's unbelieveable how different of a car it is... 140+ smooth as glass with ZERO vibes... The shaft is balanced to 8K rpms.
LS1 shaft fixed my vibes. It was a light vibe from 75-85, from 85+ it was very bad. Put in an LS1 DS, smooth as ever now.
Turns out the splines on my stock yoke had a very slight twist in them and the caps from the stock rear u-joint just fell off when it was removed. 155k miles will do that to the u-joints, but what would cause me to twist the yoke splines and not break the rear? Luck?
PS - I did break the stock spider gears hooking on a 2nd gear downshift with the 1st Spec Stage 3, would that have done that?
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
