Strange 12-bolt question
Old Jul 9, 2004 | 01:44 PM
mluke's Avatar
Question Strange 12-bolt question
I just finished changing the fluid in my Strange 12-bolt after the 1000 mile break in period. In the bottom of the case I found about 10 metal pieces that range in size from 1/2"X1/2" down to 1/8"X1/8". All of the pieces are about 1/16" thick and have a conical bend to them. The rear makes no noise, is a 3.73:1 posi, and seems to work fine. Any ideas what the pieces are from? Am I in trouble?
Thank You for any input,
Mike
Old Jul 10, 2004 | 05:33 PM
texanmutt's Avatar
Have you checked the gears yet. Sounds peices of gear. Have you beat on the car since the rear end was in.
Old Jul 10, 2004 | 05:47 PM
SABLT194's Avatar
Not Good at all! Call Strange immediately, you've got some serious problems.
Steve
Old Jul 10, 2004 | 07:24 PM
mluke's Avatar
Thanks, I'll call Strange on Monday. I don't think these pieces are hefty enough to be from gears.
Mike
Old Jul 11, 2004 | 09:56 AM
Sounds more like the tapered rollers from one of the side bearings. But you'd have a ton of noise if you lost a side bearing.
Old Jul 12, 2004 | 05:21 AM
SABLT194's Avatar
My guess is that it is hunks of side shim that got sheared off and turned into potato chips during assembly.
Steve
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
twistedwedge
Jul 27, 2002 01:54 PM
