Finally came out of denial
Old Jul 11, 2004 | 04:22 PM
Bom2000's Avatar
Unhappy Finally came out of denial
I finally stopped lying to myself and have admitted I have tranny problems. It is starting to grind more and more. I don't want it to blow on me when driving it so I am going to have it rebuilt. I want to beef it up a little bit. The car is a daily driver and when I am done with it , it will have about 400 hp so it doesn't have to be a full out bullet proof tranny unless it's worth it. I replaced the clutch about 13k ago and that seems to be fine so I won't be needing a new one right away but will replace that in time. I have a few questions about , How much will parts cost? How much will labor be? And what parts should I get? Thanks for any advise and suggestions.
Old Jul 11, 2004 | 05:26 PM
rskrause's Avatar
Moderator
There is no reason with 400hp to use anything other than OEM level parts. Without knowing what is wrong with the tranny one can't estimate repair costs. However, a rebuild kit with main case bearings, gaskets, seals, nuts, dogs & wires, thrust bearings, needle bearings, extension housing bushing, small parts kit and shifter bushings is in the $250 range retail. But it sounds like yours will need more than a routine rebuild.
Rich Krause
Old Jul 11, 2004 | 06:14 PM
Bom2000's Avatar
Thanks for the info. I just want a to beef it up a little bit to know that have that extra support. It broke once and I want to save it from breaking again anytime soon. I was thinking it was the input shaft or maybe the syncros. Does anybody know what those can run for? Thanks in advance.
Old Jul 11, 2004 | 08:51 PM
dreamer1q's Avatar
I would recommend the steel fork to anyone who has it apart. It is just good insurance.
Old Jul 13, 2004 | 01:25 PM
Bom2000's Avatar
Anybody else have any info? TTT
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
