Ring and Pinion Install Question
Old Jul 14, 2004 | 01:45 PM
slayer6x6's Avatar
I had the diff cover off my car the other day while I was changing the fluid and I noticed some kind of speed sensor mounted on the ring gear, probably the VSS. My question is how is that mounted to the ring gear? Is it bolted, pressed, and do they usually come off in one piece. Anyone run into this before?
Old Jul 14, 2004 | 09:09 PM
Mtrhds94Z's Avatar
It isn't for VSS, it's for ABS.. I haven't removed one[yet] but I know you can buy one for about 20-30 bux.. It appears to be the size of the ring gear.. I believe[ not positive] it goes under that and is held on by it..
Old Jul 14, 2004 | 09:17 PM
Capn Pete's Avatar
Yeah, that's the reluctor wheel for the ABS sensor. If you're simply changing ring & pinion though, you don't need to take it off.
Old Jul 14, 2004 | 10:59 PM
slayer6x6's Avatar
I was going to get one of the instalation kits and replace all of the bearings while I was in there.
Old Jul 15, 2004 | 04:37 AM
Capn Pete's Avatar
You can replace all the bearings without taking that off. It's built onto the carrier, and the bearings go on the outsides of the carrier.
Old Jul 15, 2004 | 11:02 AM
slayer6x6's Avatar
Sweet, thanks for the help!
oldschool
Feb 9, 2016 09:21 PM
1963SS
Feb 6, 2015 10:05 AM
TitoPR221
Jan 29, 2015 08:00 PM
4586
Jan 3, 2015 07:22 PM
Jul 4, 2005 05:00 PM
