Yet another humming F-Body!!
Ok.. I've read all the topics on humming rear ends, but I didn't see the symptoms that I am having. There is a head numbing hum coming for the readend that starts out around 30mph and slowly gets louder. But this goes away once I hit 80mph. Also when I let off the gas I hear a "chinging" noise back there as well. This I believe is related to the hum because when I give it a lil gas and the "chinging" goes away and I notice a change in the hum. There is another noise (don't know if this is related) when I reverse. It sounds like a creaking. The noise only happens when I backup and cut the wheel..like backing out of a parking space. In a straight line its fine. I guess to sum up....HELP!! Please.
Without it your limited slip wont grab correctly and will slip. It could be your problem. Easy way to tell is do a burn out and look at your tracks, if its only one tire or one is lighter then the other its slipping.
