axle removal
Old Jun 30, 2004 | 05:08 PM
spoetzel's Avatar
axle removal
i have a small squeak and i figured id start with my wheel bearings
so i remove the diff. cover take out0the lock bolt,
removed the pinion shaft
and my haynes manual says the next step is to:
"push the outer (flanged) end of the axle shaft and remove the c-lock from the inner end of the shaft"
i tried pushing everything i figured would move, is more then a simple "push" required? or is there somthing i should know......
any advice will help!!??
Old Jun 30, 2004 | 06:30 PM
iiiezekieliii's Avatar
from what i can remember (if correctly), you push the axles in, so you get access to the c-clips... you take them off, and the axles slide right off... it would be easier to take the clips off if you have a magnet or something to that effect.
Old Jun 30, 2004 | 06:33 PM
spoetzel's Avatar
so you push in from the side of the car (rr wheel)
Old Jun 30, 2004 | 07:51 PM
yeah
Old Jun 30, 2004 | 10:26 PM
Capn Pete's Avatar
Re: axle removal
Originally posted by spoetzel
so i remove the diff. cover take out the lock bolt,
How did you take out the pinion with the carrier still in there?!?!
Once you unscrewed that small little bolt, did you pull out that block or pin that goes through the center of the carrier in between the ends of the axles? Once you remove that, you should be able to push the axles in toward the center (maybe ~1/4"? ) just enough so you can get in there an pull the C-clips.
Did you remember to pull the brakes off first?
Old Jul 1, 2004 | 04:20 AM
AL SS590 M6's Avatar
Moderator
Do you have the brake calipers off yet?? If not take them off then try again.
Old Jul 3, 2004 | 05:03 PM
spoetzel's Avatar
yeah i have the brakes unhooked
and thanks for the info i got it
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Jul 10, 2015 06:29 PM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
