A/C not moving any air
Old Jun 18, 2003 | 11:53 AM
RallyRedTexan's Avatar
I think the fan portion of my A/C is going out. It seems to work intermittenly which is kinda bad down here in TX. What is the name of the part I need to replace and where can I find it? I hope it doesn't require a technician and I can do it myself. Anyone done this themselves? Thanks in advance.
Old Jun 18, 2003 | 12:02 PM
Nitromethane's Avatar
probably the blower motor - its up against the firewall pass side in engine bay.
Old Jun 18, 2003 | 06:29 PM
TheGreatJ's Avatar
Yep...and it's cake to change. There are 5 or so bolts holding it in, 7mm as I recall, and the wire harness. It just slides out...you'll have to reuse the "cage" part.
Old Jun 22, 2003 | 10:11 AM
Thanks guys!
Are there any good online places to buy?
Can I get a better fan aftermarket wise?
Old Jun 23, 2003 | 01:18 PM
Gnboy's Avatar
are you sure its not moving air or not moving air correctly check to see if it is blowing forcefull from the defrost vents. let me know
Old Jun 24, 2003 | 12:47 AM
GNboy: It's just not blowing at all. No wirring sound or anything. I think I'm gonna go with the HD version that JCWhitney sells, unless someone has a better version.
Old Jun 24, 2003 | 10:59 PM
Gnboy's Avatar
its probably out but this just popped into my head my buddy had a simalar problem with his gta and it turned out the squirrel cage and ducting were clogged with lint and crap you may want to pull it before buying a new one (most places dont take returns of electric parts)
Old Jun 25, 2003 | 04:20 PM
Thanks man, I pulled it yesterday and it all seemed to be in order. Well except that it doesn't work . Thanks for all the help guys.
HectorM52
Jul 30, 2017 11:46 AM
timmy39120
May 8, 2015 11:41 AM
alphaauto
Feb 5, 2015 05:25 PM
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
