Help With A 350 Camaro Tpi
Old Jun 23, 2003 | 09:10 PM
shwine617's Avatar
Unhappy Help With A 350 Camaro Tpi
Hi,
I have a few questions for a 1990 camaro 350 tpi.
it is an automatic and i want to put a manual trans in. would I have to do anything to the ECM to adapt the manual? what manual trans would you recommend for a street/strip car?
also what kind of rear end would be good for street/strip? Also would 24lb injectors be a good size?
thanks for reading and I would appreciate any help at all. I am just trying to make my car a little faster and stronger for the strip.
thanks again
Cory
Old Jun 26, 2003 | 07:34 PM
LSWhat's Avatar
not sure about the tranny, but 350 tpis' stock with 24lb injectors
Old Jun 26, 2003 | 10:00 PM
1fastformula's Avatar
Talking
22lbs are stock for 350's and if you want to go with a manual, the ecm will not be effected (4l60e is the electronic auto). DO NOT PUT THE 5 SPD BEHIND THE 350...go with the tremec six speed and add some 4.11s....GAWD what a dream!!!! Hook off the line and an extra gear to compensate for gearing.
Later
Old Jun 26, 2003 | 10:24 PM
Rustsucks's Avatar
I did this in my IROC and put a Tremec TKO 5 speed in mine. Worked like a charm!!! The only connection you have hanging off is the TCC conector, and you dont have to worry about it. Besides that the only other mod I made was a stick chip from GM. Good luck, its easy and worth it!
A's 91 Z28
Jan 11, 2015 10:58 AM
4586
Dec 31, 2014 02:21 PM
4586
Dec 6, 2014 05:20 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
