Replacing 700R4 with a 350, any problems???
Old Jun 18, 2003 | 03:39 AM
connyc's Avatar
Question Replacing 700R4 with a 350, any problems???
My 700R4 tranny got messed up, and I was wondering if there were any problems installing it into my 1986 Z28 (non-electronic tranny btw). Also is the 700 in my car a long or a short tail tranny? And modifications to be done? Also the tranny was given to me for free from a VERY generous friend.
Old Jun 18, 2003 | 08:46 AM
12Second3rdgen's Avatar
Re: Replacing 700R4 with a 350, any problems???
Find a 82 Camaro or Firebird with an automatic (200c) in the junkyard and take its driveshaft. Also, you will need the TH-350 swap kit from B&M which will help you with the transmission mount situation and with a place to mount the torque arm on the back.
Old Jun 18, 2003 | 09:43 PM
mjcent922's Avatar
No more overdrive
Old Jun 19, 2003 | 12:18 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Re: Re: Replacing 700R4 with a 350, any problems???
ah ok so the B&M kit will solve that problem with the torque arm as well. Im about to do this swap as well, but Im pretty sure I have the long tail-shaft TH-350 so I think I can use the same drive shaft.
Old Jun 19, 2003 | 02:56 AM
connyc's Avatar
Thumbs up
So does that mean that I've got a long tail then? And if you guys aren't sure, is there any way I can be sure it is or isn't? Thanks dudes
Old Jun 23, 2003 | 02:41 PM
S. Holley's Avatar
Measure it!! 9ins long? then you are OK...usually found on a truck or van
linz
Oct 22, 2015 07:59 AM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
draven666
Nov 26, 2014 07:16 PM
