running like crap after header /y-pipe install
this is for a friends 91 bird.
just installed some headers, y-pipe, no cat, cutout... he has flowmaster catback, 3" from the headers allllllll the way to the end
it really started to run like **** from the install... got home and checked the engine... burned though 2 wires... replaced all the wires, still crappy, got those plugwire socks, and cap, rotor... checked the firing order everything was fine. but still ran like poo
when u press on the gas... it lags and u can totally feel the lost power! it also surges when push it.... bump bump bump bump feeling... no power....
what could this be? could it be the computer?? or something... we replaced the o2 and all that jazz... hmm
HELP!
HELP!
Originally posted by jzajac1
Sounds like your 02 sensor has a poor/no ground. Run a jumper wire to the body (metal part) of the 02 sensor and the other end to battery ground, see if that straigthens it out.
Originally posted by talos
this isn't my car, im doin this for a friend, so this "paperclip" thingy-ma-bob ya... i dunno what ur talkin about
If you prefer to use a paperclip, I think there is a tech post on thirdgen.org...or you can probably do a search here.
It sound like ignition to me too. What type of wires did you guys put on there? Have you checked the coil/cap/rotor for problems?
Recheck your spark plug wire order. Make sure you have the correct firing order. Also, don't run the #5 and #7 in line with eachother from the cap to the cylinders. They should cross at the cap and run away from eachother to each cyl. Chevy 350 engines are known for this problem. The wires induce a spark into the other cyl. I think #5 is first and can induce a spark into the #7 when #5 sparks. This will misfire #7. It's been a problem ever since this engine has been around. I've also heard a lack of backpressure can cause a low power concern. I've had two vehicles that lost the exhaust after the cat. and they both lost power. I still haven't had a satisfactory answer to this. If all else fails, reinstall the original exhaust and see if the power comes back. If it does then the exhaust he bought is mismatched for his set-up. Or try putting it back in pieces, I would start with the converter and go back. Hope this helps.
