what should I do to beef up a 700R4
Subscribe
Jun 26, 2003 | 08:03 PM
I have a local shop rebuild my 4L60E and its on its way out.with the help of 1.63 60ft times. But I have a 700R4 I want to build up so the computer dont control the shifts. I dont have alot of money to get crazy just need to know where the money would be best spent. Thanks Sean
Reply
Jun 26, 2003 | 09:44 PM
Im in the process of building up my 700r4 and i have put the following parts in it. Master overhaul kit with borg warner clutches ($125), Vette servos ($25), stiffer 1-2 accumulator spring ($10), hardened steel rings for the pump ($10), shift kit ($50). Also, if your 700r4 is an 86 or older model its a good chance that it has the old 7 vane pump which im told is junk! If it has the 7 vane pump then upgrade to a 10 vane pump.
Reply
Subscribe
