Head and Cam Combo???
Old Jun 25, 2003 | 06:47 AM
lil305gta's Avatar
With my current mods what would be a good head and cam combo? I currently have a ported plenum &SLP runners waiting to be installed. I know it's justa 305 but I want to run it until it shuts down, it still runs very strong. Any suggetions would be greatly appreciated!
Old Jun 25, 2003 | 08:05 AM
SharpZ28's Avatar
I am not speaking from experience, but I have been researching the same thing for my 92 Z28. I have the SLP runners installed and have ported my plenum also. I hear good things about the Vortec GM heads, they are probably the best flowing heads for the cost. I am leaning towards a set from Air Flow Research, they are not cheap, but all the tests I have read about, they will give a substantial power gain. The cam I am thinking about will be either ZZ9 from TPIS, or GM's Hot Cam. Also a good set of headers will complement everything. I am looking to run in the 12's on street tires, and take care of late model Cobras. I hope this helps you in some way. I guess it boils down to what you want the car to do and how much your willing to spend. Good luck!
Old Jun 25, 2003 | 09:20 AM
dewey316's Avatar
pro-toplines have good flow numbers, and are a much less money that AFRs (dont' get me wrong AFR makes a GREAT product) but a set of pros in the 180cc or 200cc size would be a great fit.
as for the cam, personaly on a 305 i don't think i would go much above the 214* range on the intake side and probably not about 220* on the exaust. and for tuning i would keep the LSA at 112 or higher.
Old Jun 25, 2003 | 11:32 AM
Sitting Bull's Avatar
Grab a set of 081 heads from the junk yard, they are very inexpensive. Maybe $40 or so. Then port and polish them according to the instructions at the end of my sig. Least expensive but most powerful heads for the money anywhere!
A lot of folks like the LT1 cam for 305 roller blocks.
Old Jun 26, 2003 | 01:03 AM
lil305gta's Avatar
which of the 3 would be best
Comp Cams 266 Hydraulic Roller Camshaft, 210 / 220, .500 / .510 114 LSA, For factory roller cam engines with modified TPI and computer.
Comp Cams 264 Hydraulic Roller Camshaft, 210 / 220, .480 / .480 112 LSA, For factory roller cam engines with Tuned Port Injection and modified computer.
Comp Cams 262 Hydraulic Roller Camshaft, 206 / 210, .450 / .480 112 LSA, For factory roller cam engines with stock Tuned Port Injection and stock computer.
With my current mods and a ported plenum w/ SLP runners, and as far as heads, what about
Vortecs. Will the 64cc hurt my performance?
Old Jun 26, 2003 | 07:09 AM
dewey316's Avatar
you can have vortecs milled down to 58cc, but yes at 64cc the loss of compresion would hurt performance. you are also going to need a vortec intake base, so figure that in to the price. of everything
also not, that those are all fairly healthy cams for a 305, so computer work is def. going to be needed, esecialy since your car is a 90, so it is MAP system. so keep that in mind when picking out the cam.
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
