Should I buy??
Old Jun 20, 2003 | 12:07 PM
Zrated383's Avatar
Question Should I buy??
I have a chance to get a complete 383 motor for a very good price. However, the motor has a spun bearing. The motor only has about 5000 miles since it was rebuilt. Should I forget about it, or can it be fixed and have no effect on future performance? Any help and/or suggestions would be great!
Old Jun 20, 2003 | 12:21 PM
biff85ta's Avatar
If its a spun rod turning the crank and buying a new rod should fix it. If its a spun main the block is toast as fixing can be costly. You also need to keep in mind the crank may not clean up so you may have to buy a new crank.
Old Jun 20, 2003 | 03:19 PM
87DJP2001's Avatar
Just buying someone elses problem, may cost more then its worth. Unless you are a Pro at engine rebuilding, forget it.
warmeck
Jul 17, 2015 01:36 PM
cmsmith
Jun 4, 2015 07:35 PM
NewsBot
Jan 8, 2015 11:29 PM
