A/C vent problem
Old Jun 23, 2003 | 03:38 PM
Gnboy's Avatar
A/C vent problem
my A/C works but only blows through the defrost vents I know this is vacum ontrolled but where do I start also it does not matter whether it is a/c vent or heat it all comes out the defrost vents
Old Jun 23, 2003 | 06:46 PM
jd13's Avatar
Try taking the dash off and go from there. Follow the routing and see if the ducts open/close when adjusting the AC head unit. My IROC used to do this, but my dad surprised me and had it fixed one day.
Old Jun 23, 2003 | 07:45 PM
Gnboy's Avatar
that would work but I'd like to figure out the source of the problem before completly removing the dash
if you would ask your dad what he found
thanks
Old Jun 23, 2003 | 08:46 PM
TheGreatJ's Avatar
There's a vacuum control valve on the back of the A/C control panel that tends to develop leaks over the years....pull the panel out and see if you get vacuum to the different ports when you move the control lever.
HectorM52
Jul 30, 2017 11:46 AM
jmadoll
May 27, 2015 07:13 PM
grgguy
17
Feb 23, 2015 07:57 PM
alphaauto
Feb 5, 2015 05:25 PM
CARiD
Jan 14, 2015 04:00 AM
