700r4 13 vane pump upgrade
Old Jun 24, 2003 | 03:28 PM
slayer6x6's Avatar
Does anyone know where i can find a 13 vane pump upgrade for my 700r4? i tried looking in summit and jegs but i couldnt find anything. any suggestions?
Old Jun 24, 2003 | 03:31 PM
slayer6x6's Avatar
also, would you recommend this for a mild street/strip application? or would this upgrade only be helpful for a high performance track car.
Old Jun 24, 2003 | 07:05 PM
mrr23's Avatar
i can get the parts from the local transmission wholesale place i get my stuff from. this comes stock in 4l60e transmissions. i'm still running a 10 vane in mine. just not an absolute necessity.
Old Jun 24, 2003 | 07:33 PM
slayer6x6's Avatar
well i already have the trans disassembled and im trying to add all of the "goodies" while its out of the car (shift kit, boost valve, vette servos, etc). I know i dont NEED it, but would it be a good thing to have? If i was to go from a 10 vane to 13 vane would it increase line pressure?
Old Jun 24, 2003 | 10:17 PM
mrr23's Avatar
not that i'm aware of.
Old Jun 26, 2003 | 04:51 AM
Pro Built Automatics's Avatar
Without the "other" modifications that are done to the 4L60E, going to a 13 vane rotor setup will reduce the amount of oil volume that a 10 vane setup will produce. If you add the Trans-Go steel rings (known as no yo yo), this will solve the low pressure at hot idle and will not break. Unless the transmission has a 13 vane pump to start with, (late 1996 & up) there is no advantage to doing this.
Old Jun 26, 2003 | 03:09 PM
slayer6x6's Avatar
I did order the steel pump rings, not sure if they were made by trans go or not. Ill take your advice and stick with the 10 vane pump, thanks for the input!
Cam's maro
Jan 30, 2015 09:21 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
