Driveshaft Problem
Old Jun 8, 2003 | 09:09 AM
91_305_TPI's Avatar
Driveshaft Problem
Ok this is whats going on, One day after i was comin out of a parking lot a burned a little rubber to impress some people (you know how it is ) And as i get up to the light to stop i hear a clunking sound coming from the middle of the car.
I first thought it was the tranny but after asking around i'm pretty sure its the driveshaft but i'm not sure. The sound happens when i take off too fast or stop to abruptley.
I'm thinking it might be the UV joint in the driveshaft but what do you guys think it might be ?
Old Jun 8, 2003 | 10:03 AM
TheGreatJ's Avatar
Tranny mount...they're real bad about tearing apart on these cars.
Old Jun 8, 2003 | 12:35 PM
funina91ss's Avatar
tranny mount for sure replace it with a 1LE wich is all you can get at gm now but slp has them for 20
Old Jun 8, 2003 | 01:42 PM
aklim's Avatar
Energy Suspension has them too. They are harsh and will increase NHV but if you can put up with that, they are good.
Old Jun 8, 2003 | 02:38 PM
TheGreatJ's Avatar
Also the ES polyurethane mount won't break again as easily as a GM rubber mount.
Old Jun 8, 2003 | 04:18 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Most likely the tranny mount, but make sure its not that torque arm. I had the braket that it was in break in half once letting the torque arm bang against the top of the car.
Old Jun 8, 2003 | 04:30 PM
91_305_TPI's Avatar
Thanks guys i apprecaite it . And i forgot to mention that recently when i put it in Drive it clunks pretty bad too. And if i slam the gas when its in first it makes that clunk sounds too.
Old Jun 8, 2003 | 05:18 PM
slayer6x6's Avatar
i agree with the above posts, check out the trans mount. i was going though 1 trans mount a month until i switched to a polyurethane mount. put it in a few months ago and havent had a problem since.
Old Jun 9, 2003 | 02:36 AM
91_305_TPI's Avatar
How much does a ureathane mount usually run for?
Old Jun 9, 2003 | 10:28 AM
BOZS89IROC's Avatar
When you put it in drive and it clunks, that sounds like your U-joint. As for the rest it sounds like your tranny mount. I had to replace mine a few months ago. You want to replace it soon becausewhat your hearing clunking is a couple possible things.
1. The tail of your tranny hitting the top of the undercarrige.
2. The mid body of the trans hitting the top of the undercarrige.
Either way it's not good for your tranny, driveshaft, diff., etc. Also while your under there check out your torque arm. They are notoriously weak.
Old Jun 9, 2003 | 09:59 PM
aklim's Avatar
http://www.jegs.com/cgi-bin/ncommerc...74&prmenbr=361
About $27 from Jegs
RUENUF
Mar 13, 2016 03:39 PM
4586
Parts Wanted
May 20, 2015 10:48 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
