305 to 383 swap
Old Jun 29, 2003 | 09:14 PM
flint502's Avatar
Question 305 to 383 swap
what should i have to do to my computer after pulling a 305 and putting a 383 in it. and is there anything else i should do to the intake system??? please help
Old Jun 30, 2003 | 12:01 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I take it your TPI??
If not just correct me but I'll assult this problem as if you were.
If you are and you plan keeping it similar, your comp should be fine. Just get a new PROM chip burned for it to accelerate fuel curves and what not.
ALso with the intake you can keep the TPI harness and whatnot but I would suggest switching to a Holley Stealth Ram. It will help ou get alot more power out of that 383. TPI would starve it, especially up top. And its fairly cost effective.
Like I said, if your not TPI just say so and I will change my input. You didnt really give me enough info to go on.
Old Jun 30, 2003 | 11:30 AM
91Bird305's Avatar
Hey, ur not from Flint Michigan are you?
Old Jun 30, 2003 | 02:04 PM
flint502's Avatar
yea, i have the tpi setup. i had thought about using the stealth ram, can u still use stock computer or do u have to run the hooley computer and wiring harness??
Old Jun 30, 2003 | 07:49 PM
DarthIROC's Avatar
I think you can still run the stock computer just with an upgraded prom, same for the harness I belienve. I do know that you have to buy Holleys fuel rails though. You cant use stock ones.
Old Jun 30, 2003 | 08:00 PM
Black6SpdTA's Avatar
I read that somewhere too, but in the Summit Catalog heres what it says:
"All factory fuel injection components simply bolt on. Requires the use of a small cap distributor (remote mount coil)."
With that said, I don't know
F'n1996Z28SS
Aug 23, 2023 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
