Need Some Feedback.
Old Jun 17, 2003 | 07:21 PM
1990Iroc_Z's Avatar
Need Some Feedback.
Recently my service engine soon light would come on, so I hooked the scanner up and got a code "44" lean oxygen. So i replaced the oxygen sensor and periodically the light comes on for a while and goes away. I already tried unhooking the neg battery side and resetting the computer. Any suggestions?
Old Jun 18, 2003 | 05:30 PM
dave89gta's Avatar
Have you checked for codes since the light has come back on? Even if it doesnt stay on, I think it can trip codes.
Either way, I would disconnect the battery for about 2 mins, that will clear the computer memory, then see if you still get the light/codes.
--Dave
Old Jun 18, 2003 | 06:51 PM
Rice Killer87's Avatar
take the light bulb out
Old Jun 18, 2003 | 07:29 PM
IROC5.7TPI's Avatar
Is your car running like ****? I assume u keep it regularly maintained? If not may try replacing the fuel filter. For some reason you are experiencing an over lean condition which in turn will make your ECM try and compensate and add fuel....lots of it. You need to check fuel pressure at the rail (or carb if u have one) and if its EFI it should be at least 45PSI, carbed it should run 7-9 psi.
Get to the bottom of the situation before it really screws something up in the engine.
Old Jun 18, 2003 | 11:04 PM
91Z28-350's Avatar
Check the resistance on your injectors. If you are using stock injectors (i.e. the time bomb multecs), they will undoubtedly need to be replaced. The stockers should read a resistance of 16 ohms. I would replace them for the hell of it because those injectors will go bad and you'll spend hours trying to figure out what the hell is wrong.
Repeat, check your injectors before anything else.
Old Jun 19, 2003 | 10:42 PM
1990Iroc_Z's Avatar
Damn injectors are expensive, the fuel filter is new.
Old Jun 19, 2003 | 11:25 PM
91Z28-350's Avatar
It doesn't cost anything to check injectors yourself.
surreybrad
May 31, 2015 10:37 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
grendal
Jul 8, 2004 02:26 PM
95Z-Cross-Eyed
Jun 30, 2004 10:50 AM
