350 Questions
Old Jun 25, 2003 | 05:03 PM
LandryP's Avatar
350 Questions
My friend bought a brand new gm 350 replacement long block for his car. I have no idea what the motor is specked for (its replacing a 305) but we are having some issues with the balancer and the fuel pump. The boss for the fuel pump is there but the hole for the pushrod is not. Can it be drilled if not no big deal but the confusing part is the balancer. The end of the crank shaft where the bolt would go is filled with some sort of metal. My question is what holds the balancer on. Its off the engine right now due his putting a cam in the motor. If its pressed on how do we put it back on. Thanks in advance for any help.
Pat
Old Jun 25, 2003 | 06:53 PM
TheGreatJ's Avatar
It is pressed on in a sense, but the balancer NEEDS that bolt to hold it back against the bottom timing gear. Otherwise the timing gear may shift and cause the timing chain to snap. I don't know why the bolt hole is filled, but it certainly doesn't need to be left that way.
Old Jun 25, 2003 | 07:16 PM
LandryP's Avatar
Thats what I thought. Its wierd looking. it looks like cast aluminum was poured into the bolt hole enough that i can't tell if the threads are there or not.
Old Jun 27, 2003 | 09:22 PM
kjlvilla's Avatar
If it's a Goodwrench engine, it is probably assembled from a core. The crank hole should not be filled. The original owner probably did this and the rebuild facility didn't notice it. Even if it's an engine from an auto parts store it's probably pieces from core engines. Take it back from where you got it or ask them to see another engine and compare.
linz
Oct 22, 2015 07:59 AM
Newgmman
Feb 25, 2015 02:53 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Lederman1976
Nov 30, 2014 05:21 AM
