degreeing a cam
Old Jun 16, 2003 | 08:08 AM
zulater91's Avatar
degreeing a cam
how important is it to degree a cam or can you just line it up and throw it in.
Old Jun 16, 2003 | 01:30 PM
slayer6x6's Avatar
ive heard of people putting cams in their cars and actually loosing horsepower because the cam is so out of whack! if i were to put a cam in my car i would def. degree it.
Old Jun 16, 2003 | 02:22 PM
TunedPort 335's Avatar
I would degree it just to be safe.
Fortunately, my cam was machined correctly...and matched right up with the specs when I degreed it.
Good luck.
Old Jun 16, 2003 | 02:42 PM
zulater91's Avatar
is it hard to degree it and can you do it while the motor is in the car
Old Jun 16, 2003 | 05:03 PM
Not necessarily hard to degree, but it would be a pain with the motor inside the car.
You'll need your valve covers off, and your timing cover (obviously).
Old Jun 16, 2003 | 05:54 PM
zulater91's Avatar
thats not a problem
Old Jun 16, 2003 | 06:41 PM
Damon's Avatar
I have found good qulaity timing chains to be +- 1* in almost all cases. Good means it costs more than $50.
However, I have found in just one case that the dot was off by one tooth on the timing gear. Oops. It'll run like crap like that, obviously. And without degreeing it you'll never know that it's off.
99% of the time it'll be VERY close to spec without degreeing it. However, that 1% of the time will make you wish you had spent the time to degree it.
Old Jun 16, 2003 | 07:26 PM
zulater91's Avatar
i have a cloyes dual chain
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
