Fuel leak?
Old Jun 15, 2003 | 08:25 PM
Rollin_Sidewayz's Avatar
Fuel leak?
My friend has an 86 Iroc, and there seems to be a fuel leak coming from a part that is located towards the bottom of the block on the left side (looking at the engine from the front). It looks like fuel lines are going in and out of this part, and it is kind of dome shaped on top. Is this the fuel filter? Also, how do we know if it is a 305 or a 350? Its an 86 and its auto.
Does anyone have a diagram of the 3rd gen engines/engine bays? Thanks.
Old Jun 15, 2003 | 09:16 PM
Rice Killer87's Avatar
is it TPI or TBI? it doesnt sound like the fuel filter to me b/c thats under the car i believe towards the rear. it almost sounds like a fuel pressure regulator but thats not toward the bottom of the block..
Old Jun 15, 2003 | 09:33 PM
Well its carbuerated.. I don't know 3rd gens all too well, I'm an LT1/LS1 man. So is it the 305 or the 350? As far as the part, its the thing that the line that is labled #1 in this picture.
http://www.nastyz28.com/tech/e-fuelsys.jpg
Old Jun 15, 2003 | 09:34 PM
doug791's Avatar
no idea what it is but i know its not your fuel filter that would be located right infront of the fuel tank by the back of the car. Could there just be some loose bolts?
Old Jun 15, 2003 | 10:25 PM
I meant to say its the thing that the lined labeled #1 is coming out of.. I guess it is the fuel pressure regulator?
Old Jun 16, 2003 | 10:47 AM
TTT
Old Jun 16, 2003 | 10:54 PM
TheGreatJ's Avatar
Has everyone on the board forgotten about mechanical fuel pumps?
On the pass. side of the block at the front near the bottom.....that's your fuel pump. It's mounted to the block with 2 bolts, it has fuel lines going in and out of it, and it's cake to change. You can get one at a local parts store for next to nothing.
As far as it being a 305/350....the only way to really tell is by the casting numbers on the block.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
blac94Z
Nov 24, 2014 07:12 PM
