what tranny do I have?
Originally posted by IROC350
ya, you should have a 700. as for the tranny pan, you don't really need one
The most effective way is to get one of these:
http://www.supersportperformance.com/transcoolers.htm
They do a hell of alot more than a transmission pan
Originally posted by 87DJP2001
Actually all 3rd gen cars had 700R4 Auto's except the early years.
ok let me reword what I said for you to understand.. 700R4 were renamed 4L60s for 90-92..same animal
Originally posted by Nitromethane
That too, but I would choose a cooler over a pan - but if you want both, thats even better.
I would go with a 26,000 GVW, or at least a 20,000 depending on what size u want it to be - there is no "fit" for tranny coolers, you simply need to run the hoses from the tranny lines and wire tie the tranny cooler to the X brace in front of the radiator behind the bumper cover - im sure some people can give you mounting tips, but most people just wire tie it onto the X Brace, you don't see it anyway.
Some people use the radiator's internal transmission cooler and add a seperate cooler just to help the radiator out - but by completely bypassing the radiator, you're removing all the transmission heat from the engine coolant so reducing both transmission and coolan temps - n face it, in a 3rd gen, the coolant can stand to lose around 40 degrees
