3.08 gear
Old Jun 27, 2003 | 08:49 PM
rrapp00's Avatar
3.08 gear
Ok not really sure bout my trany but im pretty sure its a 700r4 its a 87 350 tpi auto i'm putting a 383 in it would a 3.08 gear be best.
Old Jun 27, 2003 | 09:05 PM
Slow91z's Avatar
Yes it is a 700R4....As to rear end gear, it depends on what you want to do with it....Street car?? Drag car?? Daily driver??(doubt it with a 383, but I've seen crazy stuff) Road racer?? Top speed contender??
slayer6x6's Avatar
Yes, you have a 700r4. As far as gear ratios go, it depends on the application. Is your car going to be a daliy driver, weekend street/strip, or strictly a track car?
Old Jun 27, 2003 | 09:12 PM
Slow91z's Avatar
Yeah like I said
Old Jun 27, 2003 | 09:27 PM
slayer6x6's Avatar
Oops, we must have been typing at the same time! My fault
Old Jun 27, 2003 | 11:25 PM
Slow91z's Avatar
Not a problem, I was just being smart, no actual malice intended....I was actually glad someone backed me up, being a junior member and all
Old Jun 28, 2003 | 07:36 PM
rrapp00's Avatar
Well its my regular driving car but i dont drive that much beside to the strip of course and to my gf house thats bout it well work and thats 5 mins away and i have a diff car for school
Old Jun 28, 2003 | 07:55 PM
slayer6x6's Avatar
Id go with 3.73 gears, they are a nice all around gear for the track and also the street.
Old Jun 28, 2003 | 11:36 PM
Slow91z's Avatar
Not bad, but if you like get alttile top speed going down the highway I have found that 3.42's do a great all around job, expecially if you have a torquey motor (a.k.a. TPI motors)
Old Jun 29, 2003 | 10:20 AM
TheGreatJ's Avatar
3.42 is generally considered to be the best all-around gear for the TPI motor, but if you want a little more punch and don't mind the slightly lower mileage and top speed, 3.73's are a great gearing too.
Old Jun 29, 2003 | 06:01 PM
rrapp00's Avatar
Which gear is best for accel
Old Jun 29, 2003 | 06:09 PM
slayer6x6's Avatar
If you have a higher gear ratio, more torque will be put to the wheels, but you will also have a lower top speed.
Old Jul 1, 2003 | 02:35 PM
rrapp00's Avatar
So u r saying ill spin a lil bit with the 3.73 but after its done spinning it well accel faster than the 3.08
Old Jul 1, 2003 | 03:06 PM
Slow91z's Avatar
Yes, but if you can get a 3.73 gear to hook it will be faster until you hit top speed
Old Jul 1, 2003 | 09:21 PM
rrapp00's Avatar
Good deal ho much does one of them run and where would be the best place to get it from
