Might be getting a LT1 from a 95 Caprice....
Old Jun 16, 2003 | 12:56 AM
Rally Sport's Avatar
The engine is out of a Caprice, 150K KM on it. It's from a 95 Caprice Cop Car and it has the wiring harness and computer from a buick roadmaster. I didnt know that the road masters had the LT1 also but I guess they do. Will this engine work with that computer? and if I did a small cam upgrade when rebuilding it, would I need a new chip or would it still run with that chip?
Also is it hard to get an LT1 into a 92RS??
And will my stock 700R4 tranny be ok? Or would I need to get an auto that came with an LT1
Old Jun 16, 2003 | 01:44 AM
Camaro Genius's Avatar
The LT1 will be almost a direct bolt-in, if the rs is a v-8 car. 6 banger will take some work. Get the harness and ecm from the donor car, it will save frustration later. While I've developed somewhat of a reputation of bashing the 700 r4, I doubt it will live long behind 330 hp. ,So plan on a rebuild in the near future. A tranny cooler will help it survive for a little while. While you are under there, sub frame connectors are mandatory.
Old Jun 16, 2003 | 10:57 AM
LT1Powered85Z's Avatar
Check out my website...I've got an LT1 swap guide there that has helped TONS of people.
Eric
Old Jun 16, 2003 | 04:42 PM
Perry93TransAm's Avatar
I would also yank a head to verify that its a 5.7 and not the baby LT1 , of course the emmissions sticker should denote displacement.
Old Jun 16, 2003 | 05:03 PM
Chris`s85Z28's Avatar
Hey Jesse that would be so cool if you get it tell me I`ll help you put it in
You`ll have one hell of a sleeper. Oh yeah you`ll have to get SFC like somone else said and headers and make sure it`s a 350, 350`s have a 4.00" bore if you diddn`t know
RS with LT-1
Old Jun 16, 2003 | 08:12 PM
Zepher's Avatar
The engine size is cast onto the back of the block behind the drivers side head, so no need to pull the head.
It will say either 4.3LG or 5.7LG
Old Jun 17, 2003 | 12:47 AM
96LT14u2Nv's Avatar
swap out them heads for a set of stock f-body heads (fbodys are aluminum while the caprice has cast iron heads)
the 700r4 will be okay behind the LT1 for a while. a rebuilt 700r4 will put up with the same as a 4l60e (it is essentially the same tranny)
Old Jun 17, 2003 | 01:32 PM
gun4hire's Avatar
Actually, unless you are porting the aluminum heads...the iron heads flow better which offsets the weight savings. If the Impala SS can run 13's on a stock longblock (seen it done) then a 3rd gen running the same should be able to crack 12's.
Have fun!
Old Jun 18, 2003 | 08:22 PM
redimpss5's Avatar
dude, i did this same swap you are looking at! my motor came from a 94 cop car and it was pretty easy to install. first, yes the pcm will work! second, my motor had 153,xxx miles when installed and after header install, this car is scary fast!! these engines will go 250,xxx easy! i would not worry about the head swap. you are putting in a motor that came from a 4200 pound car that was made for torque and you will put it into a car that weighs 900lb's less. there is a reason why guys who race this motor hard will take your iron heads off your hands fast! one tip, go to junk yard and get a fan from a v-6. its single fan and fits perfect. also the 700r4 works (it is the as the 4l60e cept inside) but the pcm will not know what to do because it will throw a no tranny code. call byran herder and he can program the pcm (www.pcmforless.com) to act like the six speed guys do. putting in a 4l60e is a lot easier. check lt1powededz's site. he has a lot of great tips that helped me, except i did a slightly differant motor mount setup. good luck!!
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
