trunk pull down
Old Jun 26, 2003 | 04:19 PM
GMTONY55's Avatar
trunk pull down
Does any one know if it is possible to change from power pull down to just the normal type trunk latch?
Old Jun 26, 2003 | 04:45 PM
89 IROC & EC's Avatar
I was actually thinking about doing that to my car. I was told that it could be done, but you will have to go to a junkyard or something and get the piece that connects to the body (off of a car that did not have a motorized hatch). You will then have to take out your hatch motor and the part that it bolts to and weld the new piece in. I know that's probably pretty hard to understand but I can't really explain it any better. I still haven't done it because it seems like more trouble than its really worth.
Old Jun 26, 2003 | 04:58 PM
gs400tx's Avatar
try...
http://www.top-downsolutions.com/default.php
he has most everything to fix the pull down.
Old Jun 26, 2003 | 06:24 PM
TheGreatJ's Avatar
Lon is a real good guy to do busines with. Very friendly, and more than willing to help out if you have a problem with his products. I highly recommend Top-Down Solutions.
Old Jun 26, 2003 | 08:09 PM
Aron213's Avatar
If you dont want to use it anymore...and like everyone said Lon has everything to repair it, you just take the back plastic panel, close the hatch and scribe a line where the slides are located when the hatch is closed. Then open the hatch and remove the pull down assembly...take the assembly to a welder or weld it yourself. I got tired of rebuilding mine or buying a new one off ebay and just welded it myself.
Old Jun 27, 2003 | 10:29 AM
GMTONY55's Avatar
Thanks guys.I will buy one from Lon it is $158.00 for a rebuilt one.If that one goes out I will weld it like Aron213 recommended.I love this site.
Old Jun 27, 2003 | 11:57 AM
doug791's Avatar
i figure as soon as my hatch motor dies im just welding my hatch shut and to hell with it all
Bobczar
Oct 23, 2015 11:22 AM
Noct
Jul 14, 2015 01:18 AM
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
