Headman headers
Old Jun 19, 2003 | 03:27 PM
96cam4ro's Avatar
Headman headers
I'm planning to get a set for $119 at JEGS without any emissions hookups. I also plan to get the Y-pipe for $99. Do these bolt right in or do they require some modifications? Its for a 91 TBI. Thanks.
Old Jun 19, 2003 | 03:32 PM
96cam4ro's Avatar
Oh yeah, do the stock plug wires work with these headers or do I need another type?
Old Jun 19, 2003 | 05:25 PM
Rice Killer87's Avatar
i have some on my 87 350 TPI and they are great. mine bolted right in. i had to play w/ y-pipe some b/c it wasnt perfect but hell,nothing is. buy them!
Old Jun 19, 2003 | 07:13 PM
TheGreatJ's Avatar
I got the coated Hedman shorties and absolutely LOVE them. You have to jack the driver's side of the motor up about 1.5" to get the driver's side header in, but other than that it's a very straightforward install. I chose to use wires with 90* boots and ran them under the headers....not sure if the stock style wires will work or not. I also had a custom Y-pipe built along with the 3" cat-free exhaust.
Old Jun 20, 2003 | 02:59 AM
12Second3rdgen's Avatar
The Y pipe should be fine for an L03 motor, but honestly that Y pipe sucks my ***, so if you ever go to a bigger motor down the road definately have another made.
Old Jun 20, 2003 | 03:28 PM
gun4hire's Avatar
When I got mine, I found that it was not a direct bolt-in with the factory Y pipe since they used the 3-bolt collector flanges (not the 2-bolt factory style). They also did not line up where the factory y-pipe matches up.
I intend to re-do mine at some point (longtubes?) we shall see once I get the $$$
Old Jun 21, 2003 | 02:49 PM
VortecZ28's Avatar
the only problem with the Heddman Y pipe is the pipe size, 2 1/2" if I remember right.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
