Gonna take her out to the track
Old Jun 28, 2003 | 05:10 PM
Shaun 90 Iroc's Avatar
Welp.. last time i raced it was last year and i had a few bugs holding me back.. one being a leaky tranny that shifted badly and with lag when under full throttle and another would be the main fan dieing and letting the car temp be at like 210 before getting to the start line. Best so far is a 15.2 @89.7, looking for a 14.x with new tires and a rebuilt tranny with shift kit and corvette servos, etc.
Old Jun 28, 2003 | 07:56 PM
slayer6x6's Avatar
What do you have??
Old Jun 28, 2003 | 08:45 PM
1990 Lb9, 2.73, auto.. flowmaster 80 series 3inch cat back, airfoil, msd coil, accel plug wires, splitfire plugs, stewart water pump, hypertech chip, and Rebuilt tranny with shift kit, hardened shell, corvette servos, etc.. thats about it so far on the car, going to get a base run before the mods about to go in below:
Mods to go in, in a couple of weeks.. L31 350, Stock Iron Vortec Heads with Lt4 springs, ZZ-4 cam, SDPC TPI vortec intake base, SLP 1 & 3/4th's headers, Mini-starter, New plugs, All ARP bolts, rest is the stock L31 350 (13* dome releive pistons for 9.1:1 C/R).. getting a chip from a friend with a ZZ-4 crate to start my tuning from, also: AFPR, Lakewood LCA's, Spohn SFC's and wonderbar (both powdercoated red), DS loop, Accel 23 lb injectors, GM 1.5 roller rockers... umm..that might be everything.
I am done putting the bottom end together.. got the oil pan and heads on.. roller rockers are being put on now. Looking how i want to tackle the EGR setup.. since the SDPC TPI vortec intake base is setup from the Corvette style TPI. Also had to get a new flexplate thats for the l31.. 168 tooth..
Other things to go in after.. Aluminum DS, 3.42 gears, New paint, 17 inch ROH Snypers, Black Leather 4th gen T/A seats.
Old Jun 29, 2003 | 03:58 PM
slayer6x6's Avatar
Did u put in a different torque converter with the rebuilt trans? Post up some times after you run it. Im gonna take mine to the track next week when my trans rebuild is done. I cant wait, i miss my car. Its been sitting in my driveway for 2 weeks
Old Jun 29, 2003 | 04:28 PM
Well.. since i still had the stock engine in and i knew i wouldn't be done with the 350 for 7-8 months, plus the money factor.. i just had them put in a stock style converter. Nothin special.. they didn't start runnin the clocks until like 1:45am.. and i was beat.. so i took off just before that. I will run tuesday i guess..
As far as times with the new engine.. i hope for low 13's.. some people say it would be a high 12's.. but i rather not get my hopes up and then run a 13 and be mad.
Old Jul 21, 2003 | 06:29 PM
Cynsguy's Avatar
Re: Gonna take her out to the track
That serie II rear isn't doing you any favoers running the 1/4. The only problem is you can't go higher than 308 withy the series II carrier. Any math guys able to convett his times if he ran a 373?
Old Jul 21, 2003 | 06:35 PM
slayer6x6's Avatar
Re: Re: Gonna take her out to the track
yes you can
Old Jul 21, 2003 | 09:28 PM
BadIroc's Avatar
Re: Re: Re: Gonna take her out to the track
Originally posted by slayer6x6
yes you can
yes you can, mine was originally a 2.73 rear now I got 3.73's
Old Jul 21, 2003 | 11:14 PM
slayer6x6's Avatar
Re: Re: Re: Re: Gonna take her out to the track
I am about to do the same thing. How did you like the results? Ive never been in a car to see what the begining/after change is, Im told that it feels like a completly different car.
Old Jul 21, 2003 | 11:56 PM
BadIroc's Avatar
IMO its worth it and its a wise investment. Only downfalls is that your speedo will be off about 12mph but that is fixable and your rpms will be a little bit higher on the highway cruisin' at 65. Mine runs about 2200 rpms in OD which isn't really that bad. The one this you'll definatly notice is how much faster it rips through the rpm band and quicker acceleration through your 0-60 run. Definatly worth it
Old Jul 22, 2003 | 07:33 AM
Cynsguy's Avatar
yes you can
Sorry IF i spoke out of school. I was told that the series II carriers wouldn't accept series III gears without seriously compromising the strngth of the rear. Actually, I read that info on the net so I'll have to go a google'ing. I hope you're right!
Old Jul 22, 2003 | 03:04 PM
Cynsguy's Avatar
Heres what I found out,SERIES II AND SERIES III COMPATIBILITY THREAD!
Old Jul 22, 2003 | 03:10 PM
slayer6x6's Avatar
Series 2 and series 3 ring and pinions are not interchangeable. They make 3.73's for 2 series and 3 sereis carriers. The 2 series ring gear is thicker than the 3 sereis. End of story.
Old Jul 22, 2003 | 10:07 PM
BadIroc's Avatar
any word on how he did?
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 27, 2015 09:58 PM
