idle
Old Jun 11, 2003 | 11:45 PM
doug791's Avatar
idle
1990 350. My car idles in park at around 7500 until the 02 sensor warms up and then it slows down to about 5500-6000. When it slows down it sounds like if it dropped even 250 rpm lower itd stall and VERY occasionally it does. I was just basically wondering as to what is the normal rpm that the 350s idle at when warm and if maybe i should raise mine a bit.
thx for any info
Old Jun 12, 2003 | 03:12 PM
RedIrocZ-28's Avatar
Its your IAC motor/sensor whatever you wanna call it.
You're idle is perfectly fine for a stock motor. However if your IAC is dirty/clogged then tyou should get a new one because its not letting the required "controlled vacuum leak" around the throttle blades to supply the motor with adequate idleing air.
Old Jun 12, 2003 | 03:21 PM
doug791's Avatar
yeah im not convinced its bad it only really died on me once (ive only had the car on the road a couple times i just got it) but i had been driving it really hard and then brought it to a stop in my driveway and then it died. I was looking at where the throttle cable attached to the tb and it looked like i could just adjust where it sat for the idle pretty easily. Will this work? how do i tell if my IAC is bad? Dont really want to replace things for the sake of replacing things
Old Jun 12, 2003 | 03:23 PM
Big_Z's Avatar
7500? am i missing something or does that seem dangerous to anyone else..?
Old Jun 12, 2003 | 04:32 PM
doug791's Avatar
oops ment it all in hundreds not thousands im losing my mind
Old Jun 12, 2003 | 09:02 PM
slayer6x6's Avatar
i had to read it like 10 times to make sure my brain wasnt malfunctioning
Old Jun 12, 2003 | 09:20 PM
doug791's Avatar
sorry massive brain cramp. Anyways whats the normal idling rpm for the tpi 350's once its warm and the O2 sensor is running
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
