Squeaking noise....
Old Oct 7, 2003 | 06:55 PM
kiztope's Avatar
Squeaking noise....
Well,
I am wondering if anything else besides a belt on the LS1 is prone to making a squeaking noise... it sounds a little like a belt, but when I open the hood, the noise from the motor drowns out the sound, so it is hard to locate....
Anyone have any suggestions?
Old Oct 7, 2003 | 08:17 PM
KungFu's Avatar
Could be a bearing on the water pump, A/C compressor, or something of the like.
Old Oct 8, 2003 | 03:12 PM
kiztope's Avatar
Small birds chirping.... thats a more accurate way of describing it....
Driving me nuts...
Old Oct 12, 2003 | 11:56 AM
housh's Avatar
Are you sure it is from the engine bay? I know the spare tire will squeak. Just tighten it up a bit and it will clear it right up. It has happened on a V6 I owned and my Z.
Jeffrey
Old Oct 12, 2003 | 12:49 PM
1fastV6's Avatar
small birds chirping? i had the same birds in my engine, but then they grew up and became mad eagles squawking anytime the car was started. the belts look fine (28,000 miles), still i replaced the serpintine belt and the eagles toned it down a bit, but they are still there. i plan on changing out the accessory belt soon to see if that is the problem.
please let me know if you figure it out.
Old Oct 12, 2003 | 01:18 PM
chpmnsws6's Avatar
my steering pump squeeled A TON so i just put some belt dressing and wd-40 on it and it cleans it right up....... i'm just hoping it will hold out till i can get skinnies on it
Old Oct 12, 2003 | 01:19 PM
GoFast908Z's Avatar
Member
Its the serpentine belt, replace it, if it still squeaks its probably coolant leaking onto the belt. Check the hose for leaks and the hose clamp. If any coolant gets on that belt, you have to replace it. Putting belt dressing on it will only be a temporary fix.
Old Oct 12, 2003 | 08:22 PM
VegasZ's Avatar
You will want to get the goodyear gatorback belt from auto zone. This is the belt that doesnt squeak.
Old Oct 13, 2003 | 10:51 AM
kiztope's Avatar
Well,
The birds flew away as soon as I changed the belt....
The old belt was cracked up pretty bad....
Bye bye birdy!
Old Oct 13, 2003 | 09:53 PM
1fastV6's Avatar
damn! i changed the belt and the EAGLES are back. watch out engine its time for a WD40 bath!
Old Oct 13, 2003 | 11:23 PM
Mike94ZLT1's Avatar
Mine squealed WORSE with the gatorback belt. I'm replacing the alternator tomorrow, every other thing on the front of that engine has been replaced. Drives me nuts.
Old Oct 13, 2003 | 11:57 PM
6spdpewterZ's Avatar
shoot the birds...........
Ferocity02
Dec 1, 2003 12:02 AM
Ferocity02
Aug 6, 2003 01:55 PM
camaro98_speed
Jul 31, 2003 03:44 PM
TheV6Bird
V6 Tech
9
Jul 13, 2003 11:54 AM
scoobysnax83
Feb 18, 2003 01:54 PM
