Who has done this mod?
Old Oct 9, 2003 | 02:55 PM
therealmagyver's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2435716604
Looks like a good, mod but before I do anything I post to get feedback.
Old Oct 9, 2003 | 03:20 PM
chpmnsws6's Avatar
its not worth it unless you have a turbo engine...... my talon fills up really quick but i just have a lil chrome filter on the ws6 and its never had much of anything in it
Old Oct 9, 2003 | 04:31 PM
V6toZ28's Avatar
Originally posted by robvas
I wouldn't bother. LS1's don't typically have a problem with getting their intakes full of oil, which is why most turbo import guys do this.
If you really want, just get a fuel filter at WalMart that fits in your PCV line, and stick it in there. When it gets dirty, change it out.
Actually sucking oil into the intake is a very common problem on these cars. Particularly if you've stepped up to H/C or even extensive bolt ons.
The Greddy catch can is one of the common fixes, as well as the LS6 valley cover, the 5.3 truck PCV valve, the fuel filter or an air compressor filter ...
Old Oct 9, 2003 | 05:04 PM
This why I post, before I proceed with a mod.
Thanks.
Old Oct 10, 2003 | 04:45 AM
AL SS590 M6's Avatar
Moderator
Thanks.
But they could be wrong. Many have problems with the PCV system sucking oil from the motor and injesting it. Especially when you really start spinning them up. When I put my heads/cam on this winter I'm doing the LS6 valley pan.
Old Oct 10, 2003 | 07:56 AM
I may do the fuel filter or 5.3 truck pcv....well at least look into it. What is this ls6 valley pan?
Old Oct 10, 2003 | 11:50 AM
V6toZ28's Avatar
Replace your stock LS1 valley cover with the LS6 valley cover. It runs the PCV right off the valley cover instead of the valve cover. It also has a filter built in to catch the oil ... If you haven't installed a LS6 intake yet, do it at the same time, since you have to take the intake off anyway. You will also have to chisel away a casting artifact in the valley on the LS1 block to get it to fit.
The air compressor filter is probably the most effect least expensive method ... about $20 in parts .. sort of combines the fuel filter and the catch can ...
Old Oct 10, 2003 | 02:21 PM
Air compressor filter? Where can I get one? And does anyone have a write up or is it easy once I get the part?
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
