Do the C5 rotors warp as bad as the Fbodies?
Old Oct 20, 2003 | 09:21 PM
ZDriver96's Avatar
Getting ready to do a c5 conversion and figuring out if stock or stockish rotors will withstand the dual pistons...
I tested out my LS1's at 145mph down to 50mph and warped them pretty good.
So instead of just getting new rotors... im thinking ill do another brake upgrade...
Old Oct 20, 2003 | 09:27 PM
Slappy3243's Avatar
Re: Do the C5 rotors warp as bad as the Fbodies?
145 down to 50 MPH is going to be harsh on any stock rotor no? You probably have to get some serious brakes if you will be doing that often. I would go with the upgrade if I were you.
Old Oct 20, 2003 | 09:39 PM
ZDriver96's Avatar
i rarely go up that fast... But If i do for some reason I want the brakes to be up to the challenge. The LS1 calipers gripped good but warped the rotors in the process.
Old Oct 20, 2003 | 10:40 PM
whoa guy's Avatar
Why did u do that?
Old Oct 20, 2003 | 11:14 PM
jasons93z's Avatar
There is no reason to be going that fast in the 1st place, then slamming on the brakes. Im not saying i have not gone up there, just dont do it often. You will either get killed, or arrested. For your question, some slotted rotors from jegs would work fine
meissen
Jun 1, 2015 07:59 AM
May 1, 2015 01:14 PM
jl1ne
Parts Wanted
Apr 30, 2015 10:46 PM
shroyvin56
Apr 3, 2015 08:15 AM
dale3in98
Feb 14, 2015 12:18 PM
