AC Freon released, my fault now what
Old Oct 21, 2003 | 11:24 AM
Fred94LT1's Avatar
Guys I was in the middle of swapping out the passenger side plugs on my 99 Z28 when I attempted to disconnect the AC tubing that goes into the cannister. I heard some air/gas escape. Do I have to refill the freon before I start the car so that it doesn't damage the AC Compressor? Just don't want to ruin an expensive part when I can avoid it with a little freon. Thanks,
Old Oct 21, 2003 | 11:29 AM
95GRNZ's Avatar
Arrow
I'm pretty sure the compressor has a fail-safe switch which does not allow the compressor to engage if there is not enough freon in the system, so you should be fine.
TS
Old Oct 21, 2003 | 05:55 PM
mcflyz28's Avatar
it has a low pressure switch, just leave it off till you can get it charged.
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Sep 14, 2015 02:02 AM
4586
Aug 18, 2015 07:08 AM
