teflon tape on knock sensor/stop KR
I would bet that how tight it is makes more difference than what you seal it with. It is going to grind its way thru the sealer to ground at all the high spots anyway. With pipe dope or teflon tape, if it is loose, it will probably be less sensitive. The only real way to tell would be with an o-scope.
I have heard that teflon tape on the can cause a KS code to be thrown causing a poor ground connection.
Gordon
Injector Cleaning & Flow Testing
http://www.witchhunter.com
Gordon
whitehooptie
Aug 10, 2015 07:02 AM
