Programmer for a 98?
Old Oct 7, 2003 | 03:40 PM
therealmagyver's Avatar
Which ones are out there? Predator doesn't make for my year, ls1edit is too much money and HPP3 I heard is not a good programmer. Help me out please.
Old Oct 8, 2003 | 08:38 AM
NEWBIE T/A's Avatar
Lightbulb Define programmer.
I have a HPP3 for my '99 , and am happy w/ it - it was one of the mods that came w/ the car.
But, it is not a true programmer per se - it will allow you to add the power programming, change fan settings (in preset increments, not infinitely) , adjust for different tire heights & rear axle ratios, and alter shift points & firmness (A4 cars) .
For my car - w/ stock cam, intake, a cat-back, and some free mods - that's all I need, and seat of the pants feel tells me the HPP3 works.
Other will have different opinions - welcome to the World Wide Web !
If you anticipate "heavy mods" - Heads & cam, etc. then I would bypass this and go for something like an LS1 edit that I understand (no direct experience w/) is far more versatile.
Britt
Old Oct 8, 2003 | 09:39 AM
2001SilverZ28's Avatar
The Hypertech programmers aren't really worth buying. If you really need something done then I would get it tuned.
Old Oct 8, 2003 | 03:55 PM
94ZRiCeKiLr's Avatar
Originally posted by robvas
HPP 'Power Tune' + Nitrous = Boom
of course...the HPP3 tuning advances timing....big no-no for spray...
hypertech IS worth the money if u have an auto car....shift firmness comes into play with a stall converter, shift points and rev limiter can be altered and my car now runs no hotter than 185 on the stock 195 degree thermostat.....on an M6 i wouldnt bother unless u do alot of gear changes or something...look for a used one somewhere.....they go for as low as a hndred bucks.
Old Oct 8, 2003 | 07:58 PM
Wouldn't it be a good idea to change to a 180 thermostat? Fans may work less.
Old Oct 9, 2003 | 07:09 PM
yea its definitely a good idea...unfortunately i never get around to it....lol
Old Oct 10, 2003 | 02:33 AM
projektz_born's Avatar
www.madz28.com
see him for custom programming it will be better then buying a programmer if you continue to mod
Old Oct 10, 2003 | 09:11 AM
NEWBIE T/A's Avatar
Lightbulb Won't make a difference unless you reprogram.
180 thermo may open sooner, but the fans won't kick on until the stock setting of like 217 for # 1, and 228 for # 2.
So, you are still running just as hot & the fans are working just as much.
Britt
Old Oct 10, 2003 | 06:57 PM
all i know is i optimized the cooling for the stock 195 thermo and the car runs A LOT cooler...im pretty happy with it this way...
colts0455
Sep 4, 2015 01:41 PM
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
Dec 1, 2014 08:08 AM
dreamer1q
Aug 2, 2002 09:58 AM
