Cam and Rev Limit.
A different cam may make power at a higher rpm, but you need stronger valve springs and pushrods to rev faster. These are usually done at the same time as the cam. Aftermarket cams usually have a higher lift that requires different valve springs anyway.
armedtrigger
Feb 24, 2015 08:30 PM
