valvetrain knock
Old Oct 8, 2003 | 06:54 PM
zman28000's Avatar
valvetrain knock
Okay...it has been pinpointed to the pushrod/rocker 2nd from the back on the drivers side. The pushrod isnt bent, and the rocker is good too. when the car was on with the valve cover off, the mechanic said there wasn't enough oil getting in there... I can see how that would lead to a knock, but I am getting plenty of oil pressure. Are there common problems with our oil pressure guages or pumps? Could it be a lifter or cam bearing???I need some opinions! Thanx.
Old Oct 9, 2003 | 08:09 AM
NEWBIE T/A's Avatar
Lightbulb I haven't seen any bulletins on that problem.
See here: http://web.archive.org/web/200201071...bulletins.html
for my reference.
Assuming there is not a mechanical defect causing the oil to not get to the lifter, perhaps you could try some Marvel mystery oil & see if it does any good.
Certainly can't hurt.
FWIW, a cam & lifters install (if needed/desired) runs about 1K.
Not too horrible, but then again that's a matter of perspective.
When I was in college, 1K = dam near a whole month's work during the summer !
Good Luck !
Britt
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
