LS1 service
Old Oct 17, 2003 | 01:53 PM
ShayTal's Avatar
LS1 service
Hi guys,
i lost my service manual, and was wondering if there is one online.
my 55K is due soon, and i think 60K is a major service, i need a list of things to be done.
thanks a bunch
Old Oct 17, 2003 | 02:25 PM
camaro322hp's Avatar
quote from my '99 camaro manual:
60,000 miles
* check oil life monitor. if engine oil and filter are changed, reset monitor
* change automatic transmission fluid and filter if the vehicle is mainly driven under one or more of these conditions:
- in heavy city traffic where the outside temperature regularly reaches 90F or higher
- in hilly or mountainous terrain
- when doing frequent trailer towing
- uses such as found in taxi, police or delivery service
- if you do not use your vehicle under any of these conditions, change the fluid and filter every 50,000 miles
* change the rear axle gear lubricant if vehicle is used to pull a trailer
* rotate tires
* inspect engine accessory drive belt
* replace air cleaner filter
* inspect fuel tank, cap and lines for damage or leaks. inspect fuel cap gasket for any damage. replace parts as needed.
Old Oct 17, 2003 | 02:41 PM
ShayTal's Avatar
thanks a lot... what does the 55k say ?
Old Oct 17, 2003 | 02:45 PM
there is no 55k service.
the 52,500 mile service says:
* check oil life monitor. if engine oil and filter are changed, reset monitor.
* change rear axle gear lubricant if vehicle is used to pull a trailer
* rotate tires
drive safe...
Old Oct 17, 2003 | 03:39 PM
ShayTal's Avatar
thanks alot buddy appreciate your help !
Old Oct 18, 2003 | 09:54 AM
2001NBMZ28's Avatar
Service manuals are available at http://www.engh.com/camaross/misc/ow...s/default.aspx
magman
Apr 15, 2016 03:08 AM
Ericksd
Jan 20, 2016 06:07 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
