- Puddle on the passenger side floor???
- LT1 cam specs
- ok everyone i need ur help
- 90 GMC truck help.
- Scerw, Edelbrock.
- Cody Behnke or NE people
- Got head casting #, what do you think?
- How accurate are h/p calculators?
- Question for those knowledgeable in the history...
- 383 cam, bigger or smaller?
- Crank Pulley
- 86 and 87 Engine Compartments
- Hesitation when cold?
- 15x5 rims
- The right way to set valves?
- Tack reads high.
- Summit G5000 Cam for TPI
- is that normal?
- clear tail-lights
- Need some help with the tact
- LT header clearance
- Door Lock
- Iroc Bra
- speedo needle going wacky with SGI-5 box and t56
- Bolts Busted...............
- Motor mount dilema..........
- Free/Cheap mods for 87 TPI (Vette)
- tires??
- iroc modifications
- Turbo Trans Am
- Does my 87 Trans Am have rear disc or drums?
- tuning vortec motor
- Heres a stupid question regarding 4th gen Rearend
- Hey Guys. Here!
- Front end issues, what do you think it is?
- Help me finish out my daily driver 3rd gen.....
- Help, car is getting really bad gas milage
- Dumb would this work question (O2sencor) .
- 2 Questions about exhaust
- I know this doesnt go here but....Im looking for this 3rd gen
- can't start car
- Would you guys do this?
- Heads??
- hunting idle
- wheel and tire combo
- To Anyone Who Says Their Camaro Has No Rust!
- What PROM to use?
- How I ran 14.5 in a STOCK 89...
- Corvette Heads
- need help in indy
- est. HP numbers, 383
- Detonation sucks.
- White Smoke - Full Details - Need Adviser =/
- fastest 5.0
- Carburation Intakes
- LT1/T56 swap-the best?
- '82 Z28 prices
- need your advice again 383 build up
- Losing to Civcs, need help fast
- Those who have installed carpet--Please come in.
- holley stealth ram?
- zexel-torsen differential anygood?
- 4th gen rear in a 3rd gen
- how much $$?
- Need Mod info on 305 Z
- LG4 350 HO Upgrade.... Is an intank fuel pump the only way???
- Might be getting 400 on sat just had to tell someone
- Converting my '84 to EFI: Need a fuel tank?
- Where to get a Cat Convertor for my 84 Ta? New or slightly used...
- head light adjustment
- Calling 5.7L TPI Guys - I need your measurements
- 4th gen rear end swap
- is something wrong??
- How much is my L98 Alluminum heads worth?
- What to look for in a Camaro...
- silly question
- 3rd gen wheel backspacing ???
- 153or 168 spline flexplate
- winter beaters
- How in The heck do i Fix the sagging Headliner on my 84 TA?
- My 1989 Camaro
- '88 tpi engine
- E-test 383
- How do I get my GTA to run faster?
- Hyd.roller lifters or solid flat tappet lifters
- What the h3ll is a THM700R4?
- Q: True dual Exhaust
- What should I do?
- opinions please!
- Check out classified for lots of performance parts cheap
- Easiest way to put this 12 bolt into my car?
- spark knock
- '88 Caprice 350 info??
- omg did anybody see PHR tv
- FlowMaster 80 Series Delta Force II catback, interested?
- Any one had this hapen?
- exhaust????
- Rear end swap Drum to Disc--- Pain in the Ass???
- Car died while driving. Need HELP!
- 383 sroker and t56 needs and wants
- just got my 350 block!
- Indiglo Gauges for 82-89 cars??? (w/145 speedo)
- here we go again...
- Any other cars that use the same rear end size and setup?
- Ram Jet 350 anyone??
- Anyone Need an Aftermarket Waterpump for their TPI,TBI V6?
- polishing?????????
- Which Differential Should I Get?
- GFX Question.....
- help , pinion angle
- ***383 or LT, that is the question...***
- torque converter for sale
- Hollow sway bar wall thickness
- Need a new differential
- Eibach Drag Launch springs?
- 24 lbs too much?
- wheels
- fouling plugs
- What's a good setup for autocross
- 86 TPI 305 problems
- Would 4th gen's SLP catback fit thirdgens?
- Tough Decision
- what is the difference???
- Painted the calipers chrome today
- Anyone Know much about the 1984 olympic edition camaro?
- 700r4 to a t5?
- torque converter
- 87 Z28 running too hot!!!
- IRS in 3rd gen??
- 82 Pace Car Value $$$ ???
- SB crank questions
- 1982 Z28...double hand speedometer.
- 1982 Camaro Z28----> Is This A Good Car?
- not bad for a 305?
- !!!Please help me, ignition switch hard??!!
- New front end...where? How much?
- Need help with rich problem
- Where in the heck is the ECT sensor.
- Anyone have pics of 3rd gens with Torq Thrust II's?
- Suggestions......... ???
- Smog pollution pump
- Rear hatch release motor
- stroked??bored??stroker??
- Anyone using a Mini-Ram manifold??
- leaking t-tops
- Is buying a 3rd gen worth buying to make fast?
- Anybody with 236/242 compcam???
- 5 spd queston
- cai
- need cam help
- Crank Height...
- anyone have aftermarket brakes??
- 350 Stroked to 383, bottom end buildup suggestions welcome
- Advice on a T56 swap
- New times but, E.T.-M.P.H. off, what do you guys think?
- How much for a bare block?
- 4spd manual to th350 swap??
- 9 inch rearend
- Help With Wiring Of B&m Mega Shifter!!!!!!!!!
- Rear end questions
- TPI miss...please help
- Speedo gears : tire size
- 83z in the snow
- Cam swap results
- 89 Camaro running rough
- Questions about Brake Parts
- Projected cost for T56 swap?
- Whats my 92 camaro rear housing worth?
- Caliper Switch from 1988 to 1982
- !!help!! Motor Is Missing!!
- 300RWHP, can the drivetrain/trans handle it?
- Any quality GOOD looking aftermarket GFX?
- Are Spacers Safe?
- Chips
- Descreening MAF sensors?????
- Can I use my in-radiator transmission cooler as a PS cooler?
- k member
- ls1 3rd gen
- Help on 1982 Berlinetta
- Eibach
- Flat Spots On Tires
- Please do not leave me beside the road to die!(long road trip)
- how much would these cost me?
- Part Numbers
- Best guess at HP and TQ for me please
- cam
- Anyone relocate their battery to the rear trunk?
- Help with transmissions
- 383 Build up
- If I have $200 to spend...
- I Cant Figure It Out!!
- IROC questions
- new pics with clear side markers
- It's only a broken moter mount
- Any times/dyno numbers for supercharged/383 L98?s
- All you people that have your HEI figured out
- OIL Leak, PLEASE READ
- flexplate on a 1991 RS
- Subframe connector questions
- Buying a 1992 Camaro RS v8 6.0L
- heater core replacement
- ***89 IROC and dunno wut to do***
- 700r4 to 5spd
- what is a baro sensor
- how much should i pay?
- First ever time slip...
- Will my 305 TPI run 13's N/A?
- need new trans
- a possible new purchase
- bypassing neutral safety switch
- Camaro newb :p
- Hard to shift T5 manual trans
- Thirdgenners!! firehawk wheels forsale, check it out!
- Going From TPI to Holley 4bbl... Have questions....Namely Distributor
- 87' Iroc is a *ucker to work on....
- Clutch for 84 Z28 350
- Oil Pressure
- Gaskets... anyone using ROL?
- questions about sfc and relocation brackets
- just got back from the track...
- help what do i need
- tubular k-member
- Question on this rearend
- Smooth ducting better than corrugated
- Throttle stuck wide open
- Airflow in ducts with different shaped openings
- Throttle stuck? help
- Getting a new speedo?
- Where Can I Find Adapters
- Bulletproof 700R4....maybe....need recommendations.
- LT1 cam in a 305 iroc??anygood?
- Fuse popping problem, need help bad!
- headlight switch
- Starter problems
- ????'s on TV Cable
- hooker Long tube question
- compression difference
- 383 stroker
- Saturday Tune-up, anything to watch for?
- What dipstick??
- Crossmember bolt size?????????????/
- The I-rocZ's compared to the Z-28
- Question about nitrous oxide
- Where to buy a MAF for a 3rd gen?
- Test Drove Many Camaros!
- Smells like gas
- Question for the cam experts...
- 86 TPI top end on 350 in S10
